Connectivity problem kube-proxy and Oneagent
I have configured Oneagent on K8S cluster using the following link.
After configuration, I am seeing an error “kube-proxy kube-proxy (kube-proxy-85qvd):Connectivity problem” under Problem section.
Activation of deep monitoring was unsuccessful
Monitoring of statically linked Go programs that do not load libc is not supported
I understand that kube-proxy unable to communicate on a few ports but I am not seeing any errors in Kube-proxy or dynatrace logs.
We’re running into the same issue with EKS
443 and 8443 ports are opened between k8s containers and CAG/EAG servers?
Download the support archive and check for erros in logs.
Host-->Process and Container(select the process which Activation of deep monitoring was unsuccessful) -->click on the 3 dots and download support achieve.
check the logs for errors.
Mayana Khan
hello, anyone found the answer for this?
Hello everyone,
There is now an article in Dynatrace documentation about troubleshooting issues on Kubernetes, including connectivity issues. You can check it out here:
Connectivity issues between Dynatrace and your cluster
