Control on feature sets metric in Extension
Hi Team,
Metrics in extensions 2.0 are often grouped into Feature Sets. We can only enable/disable the whole feature Set, but there is no option to pick single metrics and turn it off.
If we have an option to enable or disable it on a metric level, it will help us save our license.
Can you please have this option in coming releases.
Br,
Swaroop
You can vote this product idea.
Best regards
there’s a workaround for now until Dynatrace team respond to this great Idea that you modify the `extension.yaml` file and make your own feature set that include all the desired metrics then redeploy it and upload it as a custom extension but disadvantages of this method is that you’ll need to update your extension with each update coming from its vendor.
BR,
Mostafa Hussein.
