Converting splunk query to DQL timeseries
I am in process of rebuilding all of our Splunk Dashboards over to Dynatrace Dashboards. A lot of our Dashboards are asking us for the latest value. Below is the splunk query.
| mstats latest(vault.token.count.by_auth.value) as count where `vault_telemetry` AND cluster=* AND namespace IN (“*”) by cluster,namespace,auth_method span=10m
| stats sum(count) as count by _time,auth_method
| eventstats latest(_time) as latesttime
| where _time == latesttime
| stats max(count) as count by auth_method
Maybe I am approaching this issue wrong but I would think you would need to do a time series for and some how pull the latest value in like an array and then do something with it to make this happen. Any advice would greatly be apperciated.
Hey esm, if you want to pull the latest value from a timeseries you could do something like:
timeseries count = count(dt.host.availability)
| fields count = arrayLast(count)
This would return 1 field called count containing the latest value. For more information regarding available array functions including examples you can find them here: Array functions — Dynatrace Docs
