I have a set of python scripts used for extract of timeseries metrics using Metrics API v2. Reason is to repetitively extract detailed statistics for long term capacity planning - to avoid the issue that eventually, when the data is needed for planning - dynatrace would have long summarised it in hourly or daily averages. Yep - capacity planners do like to have access to piles of data (different discussion).
Staying on topic… I am unable to figure out how to correlate multiple attached entities to host entity. For example in human readable form host is usually a hostName not entitiyId that looks like ‘HOST-XXXXXXXXX’. That host usually has multiple disks attached, each with its own metrics:
so:
HOST-1234567 (myhost.com): DISK-12345 (C:\), DISK-12346 (F:\)
I am unable to create the relationship that allows me to extract disk utilisation data for:
myhost.com/disk-c:<br>myhost.com/disk-f:
My process is to - find a host from the list of all host entities by matching hostName from the resulting list of hosts entities.
I can then use this entity to extract CPU/MEMORY time series data - that is fine
BUT, I can’t find the way of extracting DISK utilisation for a particular disk. Interestingly, the Metrics v2 API returns this:
"metrics": {<br> "builtin:host.disk.used": {<br> "series": [<br> {<br> "dimensions": [<br> <strong>"HOST-9483C7D89472AF43"</strong>,<br> <strong>"DISK-51D7D5BE9D2A1FE2"</strong><br> ],<br> "values": [<br> {<br> "timestamp": 1568095200000,<br> "value": 5.170616996598518E10<br> },<br>ETC...
I can’t, for the life of me, find what the “DISK-51D7D5BE9D2A1FE2” actually is - is it a C:\ or F:\ drive? There seem to be no way of correlating these or even finding out the ‘human readable’ description/name of the entity/device. The devices are not listed in the host entity detailed information.
Anyone can point me in the direction of how the configuration (host:disk[X] or host:cpu[x] or host:netinterface[X]) works? Docs? Tutorials? Any API architects? Any E-R diagrams of how the structure is supposed to look like? Any Dynatrace API libraries usable by python that allow something like ‘getDiskByHostName(host)’ lol ?
Thanks for reading this…
