Hello there. Give some advice please.
I’ve a 6-node cluster and its suffering Cassandra degradation.
One of features to stabileze normal working is to disable collecting data from oneagent.
after disabling oneagent traffic i’m getting an error:
Could not forsake node nodename. Check logs for details..
There is no helpful information in logs, only mesages like that
2020-06-30 06:27:16 UTC Launching command: /app/dynatrace/bin/installer/bin/configurator --cluster-nodes set-json {“clusterNodes”:[{“id”:1,“ipAddress”:“10.x.x.x”,“webUI”:true,“agent”:true,“datacenter”:“”},{“id”:2,“ipAddress”:“10.x.x.x”,“webUI”:true,“agent”:true,“datacenter”:“”},{“id”:3,“ipAddress”:“10.x.x.x”,“webUI”:true,“agent”:true,“datacenter”:“”},
{“id”:4,“ipAddress”:“10.x.x.x”,“webUI”:true,“agent”:true,“datacenter”:“”},{“id”:5,“ipAddress”:“10.x.x.x”,“webUI”:true,“agent”:true,“datacenter”:“”},{“id”:6,“ipAddress”:“10.x.x.x”,“webUI”:true,“agent”:true,“datacenter”:“”}]}
2020-06-30 06:27:17 UTC Launching command: /app/dynatrace/bin/installer/bin/configurator --cluster-nodes get-all-json
2020-06-30 06:27:17 UTC Failed, with exit code 10
What does it mean? In CMC I see that these nodes are in OneAgent traffic disabled mode, but it’s really is?
How to check that it’s ok with nodes and they are working properly?
