Dear community members,
I need a custom DQL queries for fetching hosts via custom host metadata or Tags.
If there are practical use cases that would be appreciated.
BR,
Peter
BR,
Peter
@Peter_Youssef You can try the below DQL
fetch dt.entity.host
| fieldsAdd entity.type, monitoringMode,memoryTotal, physicalMemory, tags, managementZones, networkZone
| filter matchesValue(tags, "TIER:GOLD")
thanks for your inputs, I’ll try and keep you posted.
Thanks for your support, I’ve applied the DQL statements as per actual setup, It’s not working.
Are there other DQL Queries to fetch the required Hosts information
KR,
Peter
@Peter_Youssef the above DQL should work fine without any issues , what error do you see when you run the query. Please make sure you are using the right tags as filter to see the hosts
Hey @Peter_Youssef ,
I just wanted to check in and see if you still need help with this. If so, I’d be happy to look into it for you! :blush:
