CPU cores visibility
Hi
Is it possible to view no. of CPU cores for a host in Dynatrace UI with oneagent installed?
Srikanth
In Properties & Tags you can easily see that information:
Having this as a metric would be useful
Looks like a nice product idea đꙂ
Best regards
I’m curious what will this metric show? Some kind of changes of the cpu cores in time, or? Can’t we make a custom metric via DQL timeseries?  - we have fetch “dt.entity.host” with column cpuCores?
Thanks!
Regards, Deni
@deni
Not a fan of getting metrics that will almost always show the same value. But a couple of cases I’ve seen in the past come to mind:
  • You’ve got a system that suddenly spikes from 25% to 50%. It was shown that the number of CPUs dropped from 4 to 2, and one process was stuck.
  • Everyone praised that a process had been made more efficient. But then we proved that the system had more cores…
Thanks!
That makes sense — I was assuming the values in the time series would always be the same :slightly_smiling_face:.
I’m still learning the details of DQL (actually, the Community is where I learn the most — that’s why I keep checking other questions and searching for clarifications). But isn’t it possible to create a time series directly from something like this?
fetch dt.entity.host
| fields id, cpuCores
| filter isNotNull(cpuCores)
I couldn’t get it to work yet, and I still don’t fully understand how | makeTimeseries works. But I was imagining something like:
| fields id, cpuCores
| makeTimeseries sum(cpuCores), by: {id}, time: now()
Thanks again!
Regards, Deni
This isnt available in DT Managed.
