Crash on iOS, seemingly within the Dynatrace SDK
We’re seeing some crashes reported on TestFlight that seem to be originating from the Dynatrace SDK.
The crashes are happening on startup and have a stack trace that looks like the following:
Exception Type:  EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Reason: -[NSNull UTF8String]: unrecognized selector sent to instance 0x1ffdcb540
Termination Reason: SIGNAL 6 Abort trap: 6
Thread 12 name:
Thread 12 Crashed:
0   libsystem_kernel.dylib        	0x00000001ea8f51d4 __pthread_kill + 8 (:-1)
1   libsystem_pthread.dylib       	0x0000000222a62ef8 pthread_kill + 268 (pthread.c:1721)
2   libsystem_c.dylib             	0x00000001a22e7ad8 abort + 128 (abort.c:122)
3   libc++abi.dylib               	0x00000002228715b8 abort_message + 132 (abort_message.cpp:78)
4   libc++abi.dylib               	0x000000022285fbac demangling_terminate_handler() + 348 (cxa_default_handlers.cpp:77)
5   libobjc.A.dylib               	0x0000000197846e14 _objc_terminate() + 156 (objc-exception.mm:496)
6   libc++abi.dylib               	0x000000022287087c std::__terminate(void (*)()) + 16 (cxa_handlers.cpp:59)
7   libc++abi.dylib               	0x0000000222873dfc __cxxabiv1::failed_throw(__cxxabiv1::__cxa_exception*) + 88 (cxa_exception.cpp:152)
8   libc++abi.dylib               	0x0000000222873da4 __cxa_throw + 92 (cxa_exception.cpp:294)
9   libobjc.A.dylib               	0x000000019782b44c objc_exception_throw + 448 (objc-exception.mm:385)
10  CoreFoundation                	0x000000019a65e8c8 -[NSObject(NSObject) doesNotRecognizeSelector:] + 364 (NSObject.m:162)
11  CoreFoundation                	0x000000019a4f6b08 ___forwarding___ + 1560 (NSForwarding.m:3612)
12  CoreFoundation                	0x000000019a4f6430 _CF_forwarding_prep_0 + 96 (:-1)
13  Dynatrace                     	0x00000001063bdc4c -[DTXSqliteAbstractionLayer insertCrashReportForSessionIdentification:reportInfo:] + 384
14  Dynatrace                     	0x00000001063e4d60 -[DTXDBManager processDBQueue] + 3128
15  Dynatrace                     	0x00000001063e86d0 -[DTXDBManager(Private) run] + 132 (:-1)
16  Foundation                    	0x00000001991e16c8 __NSThread__start__ + 724 (NSThread.m:991)
17  libsystem_pthread.dylib       	0x0000000222a6137c _pthread_start + 136 (pthread.c:931)
18  libsystem_pthread.dylib       	0x0000000222a5c494 thread_start + 8 (:-1)
We are using version 8.301.1 of the Swift package.
One thing that may be a factor is we are replacing an installed version of the app developed in Xamarin (using the nuget package version 8.271.2) with a native app (using the above Swift package).
Oliver
This was handled in a support case and will be fixed with 8.309
