We want to enable a certain group of people to only view a limited amount of servers, this is the easy part.
However we also want to ensure that this group only can watch data 2days back, but they are still allowed to make a window of 30min.
This could be as part of monitoring network or docker information.
Worst case, would it be possible to create a dashboard where in the data-explorer is the 2 days limit, but they can on top of this restrict it to 30min?
The only way to limit it is to provide them with a predefined dashboard and share it anonymously. Then they can only see the dashboard with the set timeframe. They can only see what is on the dashboard.
When you give them login credentials, they can see the data in their scopes for any timeframe.
