Create a metric with JMX Operations return value
I have a mbean operation which based on passed string values (2 count) will return a numeric value. I want to collect the returned numeric value to create a metric
com.abc:type=TrackedValues has a JMX Operation getAverage(“A”,“B”) which returns a numeric value
Hello Dynanoob,
The only way I know it is possible to capture this information inside Dynatrace is by creating a JMX extension that will let you inject this as a metric inside Dynatrace.
Creating an Extension for it is pretty easy with the 2.0 framework and link to the documentation. I recommend you to watch this video. It is an excellent demo of how to perform what you need.
Hope you a good monitoring! In no time, you’ll become dynaPro!
