Create Custom Metric from missing log entries
I created a metric “cluster-availability” using Log Monitoring - Metric extraction (mointoring availability of a JDBC database by checking the log entries which are ingested by custom extension/SQL data source). In this way I get the value of availability which I can use in chart.
I want to create a metric that shows the unavailability which would concern the missing datapoints of metric “cluster-availability”
How can I do this?
Thank you very much for your help.
What does your metric data look like during times of unavailability? Are you getting ‘null’ values or something else?
Hi there,
Thanks for your reply. During times of unavailability it’s lacking datapoints, since in this case datapoints are only created when the cluster is available. I could use the default(0,always)
<span><br>db_cluster.avail:filter(eq("dt.entity.custom:my_db_cluster",CUSTOM_DEVICE-XXXX)):splitBy("dt.entity.custom:my_db_cluster"):<strong>default(0,always)<br><br></strong><br></span>
So I could set “0” for the missing datapoint.
Thanks for your support.
You can use Missing data alert parameter.
Thanks for your reply. The anomaly detection/missing-data is in place. However additonally the requirement is to display the unavailbity within a chart oder dashboard.
Kind regards,
