How can you create an anomaly detector in Davis Anomaly Detection app?
You can create an anomaly detector on time series regardless of origin—whether generated with makeTimeseries from events, bizevents, logs, or other sources.
If you have the pre-defined DQL for your use case and know which analyzer to use, you can create a Davis anomaly detector in the Davis Anomaly Detection app.
However, I recommend simulating the Davis AI analyzer in Notebooks (explained here) to understand better how it behaves with your DQL and optimize it according to your needs.
