I have an issue with the metrics on my Informix dashboard not being displayed correctly because the extension I am using is still on version 1.0. According to the documentation, migrating to version 2.0 is necessary for the metrics to be displayed properly.
Is there any alternative solution or a temporary workaround to view the metrics while we migrate to version 2.0?
If my ActiveGate was updated before I realized the issue that Informix would no longer be monitored with extension 1.0, would it be possible to install another ActiveGate with the previous version? Also, I was informed that the Informix extension in the Hub would be available by the end of December. Do you have any information about this?
@Mike_L am i missing something here? The expression from the site you linked above works fine but when put into the extension, schema 1.309 it doesn’t work. If I remove a character like the first 0 then the extension seems to like it but according to the site above, removing the first 0 leads to an undefined expression
