This message was sent out to all accounts we believe are affected by this discontinuation.
There is an accompanying blog post coming with additional information. We are also working on a how-to guide on how to convert Python extensions to the new framework as soon as customers and partners can do that.
I have forwarded this thread to the work group who are busy with the EF1 removal.
Yes, that’s true. Unfortunately, Python Code Extensions 2.0 are not even available yet. We definitely need to know what the sunset in October 2024 means. Extensions will stop working completely? Just new extensions could not be added? Just support will be discontinued and the extensions will keep working?
Even with a successful conversion, there can be quite a significant impact on existing customers in terms of DDUs, as the EF2 is based on a continuous “data-stream” (logs/events/metrics/…) to have the entities created and alive (at least once in 15 minutes). There is currently no option to create the entities without it as it was possible in EF1.
There are so many doubts about this, but I’m forwarding this internally. We have about 40 extensions, some 10 to 15 scheduled, and I knew this from a client?
Python extensions in EF2 is scheduled to be available somewhere around Perform. We are aiming to release the how-to guides on conversions in December or January so people can prepare for it.
The sunset date means that we will remove the extension framework from OneAgents and ActiveGates.
If you are aware of use cases which is not possible with Extension Framework 2.0 our product management team will be interested to hear about that.
We will provide some automation scripts as part of the vscode plugin from my team to simplify the conversions of Python extensions, such as converting a part of the plugin.json file. We are also able to help out through Dynatrace services if the 12 month advance notice is too limited for planning.
There are so many questions that have arised in the last two hours, since I was notified of this. The Community is certainly not the place to put them, so I have channeled them internally. I hope to get replies really fast.
We all value your contributions here, and especially how fast they are. But I’ll repeat what I said initially, given what else I have discovered in the meantime: this sunset timing is not reasonable, and in my opinion, not doable…
Probably for a while, but it is uncertain for how long. I recommend against it though as Python 3.8 is out of support in October 2024 so you would be running unsupported software on your OAs/AGs.
There are many reasons behind this decision. It all boils down to providing our customers with the best possible option for extending the Dynatrace platform so we can invest in a best in class, supported, easy, scalable, secure framework.
Dynatrace reconsiders not retiring support for the framework, in the terms announced, given that not even today there is a clear understanding of how EF2 will support many of the existing EF1 possibilities.
Now that we can’t get the cat in the box again, Dynatrace has to publicly reference on how it will support it’s frameworks&features in the future, including naturally EF2, but also SDKs, Unified Analysis View, AppEngine, AutomationEngine, etc. We, developers, Partners and especially Clients, need to have a clear understanding of Dynatrace’s commitment to each one of them
You’re absolutely correct - I acknowledge that our communication with the experts could have been handled better. In September we did have two internal messages shared, followed now by this public message to customers. We are providing a 12-month window prior to the End-of-Life (EOL) of Extension Framework 1.0 (EF1.0). And as we understand that this timeframe may not suffice for some of you, and we want to ensure that Dynatrace will support you in various ways. Starting from automated JMX conversion to dedicated trainings on Python migration.
When we introduced Extension Framework 2.0 (EF2.0) in March 2021 (blog) we already mentioned that EF1.0 would eventually be phased out. Subsequently, our primary focus has been on maximizing the value of the new EF2.0, resulting in limited investments in EF1.0. As a result, maintaining its functionality and security beyond October '24 is not feasible especially that Python 3.8 (base for custom plugins) will reach end of life then.
You’ve rightly brought up the issue of feature parity between EF2 and EF1. While I agree that we may not have all the same functionalities in EF2 as we did with plugins, we are actively working to bridge most of these gaps or provide suitable workarounds. It’s worth noting that a similar process occurred with Custom Charts, where functionalities were added during 12-month period after deprecation was announced.
In the meantime, I suggest we focus on two key areas:
How we can assist you and other customers with the migration to EF2.
Prioritizing the gaps that need attention.
Looking forward to discuss further
Michal Nalezinski (Senior Product Manager)
Dynatrace Enterprise Applications and Services
I have transmitted internally many issues that I believe are important. You should have access to them, and I’ll use the correct forums to deal with them. And that includes the two key areas you mention.
Now, here in the Community, we have to address at least the following:
Dynatrace has to come forward and say how and till when will functionalities & features be supported? If not, developers, Partners and especially Clients, will not be able to build with confidence in the Dynatrace platform.
Framing this as a python 3.8 support issue is unbelievable for me!
Communication was deplorable, especially because the only notice I received was from one of the few tenants that I follow that doesn’t have a single EF1 extension.
I hope we don’t go the way Custom Charts went. Still today, two and a half years later, it still has at least one feature very important to me, that is not supported elsewhere by Dynatrace.
Finally, I would say that this is a problem that at the moment few of us have a real perception of the impacts. I have talked to several other EF1 developers, and treatment was the same. Fortunately, clients don’t know the real impacts this will have, at least for now.
@michal_nalezin where can we track the gaps and features, so we can speed up the feature parity? Product Ideas here in the community?
The largest gaps I see are:
unable to create topology without continuous data stream (in EF1 you don’t need any metric/log/event to have the topology). Despite this achievable by sending log/events or metric, it will would significant impact on the customers in terms of DDU as they may not have it in the budget or the extension value may drop due to increased cost in Dynatrace licenses.
There are no relations between Dynatrace builtin entities and custom topology entities based on IP addresses / ports, I had a support ticket opened a year ago for that https://one.dynatrace.com/hc/en-us/requests/99626 and it still does not seem to be working as in EF1.
No possibility to have a link on the EF2.0 entity screen to an external system. EF1 had the button “Show details” which was used to open a source system (source of the data). Customers use that heavily with our Nagios and Zabbix extensions.
And yes, at least partners with existing extensions in the HUB need to have access to code-level extensions, preferably prior to Perform. We have existing customers, re-developing the extensions in EF2 will take some time and also we need to reach out to our customers to deploy it.
Hi Julius, I’m curious about your use case where you want to create topology but not ingest any data. What would be the purpose of the entity, if you don’t intend to send in any metrics or events for it?
