Last November, we were told that Dynatrace was “working on migrating the Extensions 1.0 that were provided to you out-of-the-box or were published by Dynatrace on the Hub.” (in Unmatched scalability and security of Dynatrace extensions)
All EF1 extensions which were scheduled for migration were migrated and added to the hub by April.
Approximately 20 extensions were not migrated. This is the list, I am not sure why custom DB Query is not on that list, I will ask the PM: End-of-support announcements — Dynatrace Docs
Hi @AntonioSousa
As Mike mentioned, ping, port (and DNS) will be replaced by completely new approach, synthetic network monitors, with significantly enhanced functionality, for example single monitor handling list of selected hosts/devices (IP addresses/ports) or all hosts belonging to given host group. However, consequence of such approach is that we will not be able to maintain data continuity, as, basically, completely new monitors need to be created.
Good news is that, as in case of all synthetic monitors, there is standard synthetic API for managing tests. Some of our preview participants used it for generating new monitors based on extensions configuration automatically.
Thank you, Antonio, for sharing your feedback. Even though it has slightly bitter taste for me, I truly appreciate it and consider it very valuable.
Sometimes transitioning to a new, better solution comes with consequences, and maintaining full data continuity isn’t always feasible. However, I’ve taken note of your input, and we’ll work on making the switch to the new solution as seamless as possible.
