one of the use cases integrating other 3rd party monitoring tools such as Zabbix and Nagios. Both those extensions are already in the Dynatrace HUB and we have several customers using them. Our two extensions create entities in smartscape and send problem opening events based on problem data in the integrated monitoring system.
Benefits customers are now using:
relations between OneAgent monitored entities and entities monitored just by the integrated system, for example for feeding CMDB as @AntonioSousa already mentions.
As far as I tested, this feature is still not available in EF2 and relations between OneAgent monitored entities and custom topology are still not created as it is in EF1.
Unified problem view - customers see problems from several monitoring tools in Dynatrace
Typically it’s not beneficial just to pump metrics from one tool to another, so we have no continuous data stream. In EF2 we would need to send “dummy” data and the customer will need to pay DDUs for that. Customers really take DDU consumption into account.
@AurelienGravier, thanks for the notice :grinning_face_with_smiling_eyes:
Unfortunately, nothing really new is said, while introducing even more doubt on the process…
The worst part is that this clearly undermines confidence in developers developing in Dynatrace. In a Platform that is trying to move forward convincing developers to invest into it, this is not a good signal for them/us.
Thanks. I know about Perform training, but there are several problems with that:
We still have almost 3 months till Perform
As Partners, we are intending to be present at the Partner Summit, so that invalidates Tuesday
Being there an additional day has a cost
HoT sessions are $500 for each attendee…
Fortunately, haven’t booked flights & hotel yet, but probably not attending the HoT session, given that only one of the five points seems interesting to me.
As a developer of about 50 custom Oneagent and a couple of activegate EF1 extensions I was shocked to get these news. Especially since the Python scripts in EF2 is not available yet. From the planned release of Python scripts I will have to convert two extensions a week until EOL, which is a lot of technical debt.
Please consider me as an early adopter of EF2.0 python scripts and the documentation since this is of high criticality.
I have already written a couple of EF2.0 extensions, so I am familiar with most concepts.
Also, will the HoT session be available virtually?
As partner, we are invited to attend a first workshop this Thursday titled “migrating Python-coded extensions from old Extension Framework 1.0 to new version 2.0”.
The positive aspect is that the Dynatrace team doesn’t rely on Perform to offer insights regarding this End of Life (EoL) situation. I appreciate it.
Yes, the JMX/PMI wizard will be deprecated as well. What we are looking to do instead is to expose the JMX class browser over API and integrate it into our VScode addon for extensions. This will enable automatic creation of EF2 JMX extensions just like we do for Prometheus for example.
It is not yet certain that a PMI data source will be created for extension framework 2.0. This is currently being discussed based on PMI being deprecated for quite some time.
Since we are bringing up the custom chart conversion, may we suggest the same approach for EF2. A big button developed by Dynatrace to handle the upgrade ?
The information on removing EF1.0 was out in November’23. That was the moment when most of partners and customers notified us about the aggressive timeline of 12 months.
Meanwhile, Dynatrace was releasing Python data source related items since December. We have provided dedicated trainings for partners, early access, VScode addon, etc.
If we can support you more, let’s connect directly.
Best regards
Michal Nalezinski
the notification that Python extensions “will be available” around perform didn’t make me start converting extensions as I couldn’t participate in the EAP. So the clock startet around March where we could get a pre-prod environment of the customer enabled for Python ext. 2.0.
But it won’t help getting test and approval processes sped up - not in our hands and the customer is certainly not risking incompliance with banking authorities for our plugins. Also I can’t just quickly onboard any member of the Services team of Dynatrace and try to make them help with development and testing…
My guess is that the customer will move plugin functionality to systems monitoring tools and away from Dynatrace…
Automating part of the process is not “automatic migration”, we are working to help as much as possible, including things like:
converting plugin.json (done)
migrating dependencies to setup.py
Setting extension metadata on extension.yaml
copying your source code files to the extension directory
but migrating the actual lines of code is not something that we will do, this will require manual intervention because of the nature of software development and the change in concepts like MINT metrics with Topology vs Custom Devices
We are looking to add some of these extra features in the upcoming weeks
