I am trying to create a DQL to measure the current request count as percentage of the baseline. I intend to use it in an SLO configuration.
I tried something like this:
timeseries { today=sum(dt.service.request.count),by: { dt.entity.service }, interval:1m}
| append [ timeseries {yesterday=sum(dt.service.request.count),by: { dt.entity.service }, shift:-24h, interval:1m} ]
| filter dt.entity.service==“SERVICE-ABC”
| fieldsAdd sli=((today[]/yesterday[])*(100))
But this gives me just one data point and not a time series.
I also looked into the documentation but can not find any details on how to achieve this.
Good day, @OnkarShinde
Try to replace the append by lookup instead.
| lookup [ timeseries {yesterday=sum(dt.service.request.count)
,by: { dt.entity.service }, shift:-24h, interval:1m} ] , sourceField:dt.entity.service, lookupField:dt.entity.service
| filter dt.entity.service=="SERVICE-ABC"
| fieldsAdd sli=((today[]/lookup.yesterday[])*(100))
Try and let us know.
The issue is that append stacks rows from the subquery; it doesn’t place yesterday into the same record as today. So you end up dividing values that usually don’t coexist in one row, which effectively collapses to a single meaningful point (or mostly nulls). Use a join.
Try this:
timeseries today = sum(dt.service.request.count, default: 0),
interval: 1m
| filter dt.entity.service == "SERVICE-076EAECF9109883D"
| join on: { dt.entity.service, interval }, [
timeseries yesterday = sum(dt.service.request.count, default: 0),
shift: -24h,
interval: 1m
], fields: { yesterday }
| fieldsAdd sli = if(yesterday[] == 0, 0, else: (today[] / yesterday[]) * 100)
Should the last line be changed to?
fieldsAdd sli = if(yesterday[] == 0, 100, else: (today[] / yesterday[]) * 100)
If there were no requests yesterday why should the SLI be considered 0, I would rather consider them 100? The intent is to detect the drop in the requests, don’t care if there is increase compared to yestertday
I tried to use this in a notebook. But when I try to validate my anomaly detection settings with this query it is not working. The query below with join is working for me.
