Custom Alerting - BatchJob Method Innvocation Count
I have defined my Batchjobs as a key service
I have 3 Batchjobs,
(1) runs/hour
(2) runs/24hour and
the 3rd one runs/week
All i want is to be alerted if the Batchjobs method invocation is <1,  does not get executed in an hour or in 24 Hours & in the 3rd case once a week
If BatchJob() count is below <1 in an hour, raise an alert …This would tell me the BatchJob has not executed in its pre defined execution times
Is this even possible in custom alerting? how ?
I treid using RequestCount
but looks like its averging the count which is not i want
as the average value is below 1 …looks like its throughput/min
All i am looking for is when method innvocation count is <1 for more than 24 hours, fire an email alert
Hello @shahrukh_niazi
You can create a Multidimensional analysis for the key request with the following:
Then create a calculated metric.
Then Create a custom event for alerting.
Then you can use this custom event for alerting profile.
Babar
Thanks Baber. That was it.
I have few BatchJobs that runs daily from 8am to 6pm.  They remain off on weekends and after 6pm business days. I doubt Dynatrace can map alerting based on the above conditions. Alert only during business hours if count <1  , or in some cases they run on Weekends only , one time on Saturday & once on weekend.
I doubt this alerting requirement can be mapped to Dynatrace alerting profile
You can use the maintenance windows for this purpose.
Babar
