Custom extension for Databases
hi all,
I am new to dynatrace and working on custom query extension. I want  SQL query to execute at 1min interval and provide the metrics. From VS code i deployed the custom extension. Beyond that what is the format to add query to yaml file and start monitoring ?
requirement:
need to get the metrics for following SQL query
select * from (select sql_text, elapsed_time/1000000 from sys.v_$sqlarea order by 2 desc) where rownum < 21;
Please help me out. Thanks
If someone has the custom query extension yaml file with SQL query monitored, pls provide to use it as template
You have a SQL data source reference. It might be helpful.
Best regards
Have you tried the doc skeleton?
On top of the other links people already shared, I recommend this video for a step by step guide:
Thank you all, got exactly what I wanted.
Is it possible to define a variable for the interval (10 minutes) and use it in the query?
