Customer want to see a graphic (data explorer tile) for today.
The main reason - to have to see 13 work hours.
Another graphic (data explorer tule) for yesterday - we have start at 8:00 and last time is 21:00
Why Dynatrace can’t provide to me same funcional for “today”
As you can see this interval will be only ~6 hours - and I can`t have same visualisation.
In previos versions it works without any problems and I have
13 == 8:00-->21:00 for today tile
13 == 8:00-->21:00 for yesterday tile.
Now I have:
6 hours == 8:00-->current time(13:00) NOT for 21:00… for today tile
13 hours == 8:00-->21:00 for yesterday tile.
How I can fix this and make Customer happy?
Romanenkov Alex
Hi @Romanenkov_Al3x, the timeframe selector doesn’t allow you to set up a date/time in the future, as you likely already know.
However, you could use it like this example, where the date today is 6 March 2023: 2023-03-06 08:00 to now/m, which should give you today 08:00 to the latest timestamp, in my case today 23:20.
Granted, it won’t completely satisfy your requirement to have two charts, each showing 08:00-21:00, with one for today and one for yesterday, but it is the closest you’ll get to that in my opinion.
HTH,
André
Solution was to work with time-selector:
for work hours = yesterday+8h to yesterday+21h
and then for current time use timeshift - +1d - “now line”
for values that was - 7days ago - (-6d) - “week ago line”
without timeshift - yesterday “line”
@andre_vdveen big thanks for tips.
Now we need RFE for dotted lines
Alex Romanenkov
I found this in the documentation and thought it might be helpful to post it here since the timeframe selector was the topic:
Timeframe selector expressions
