I have a variable that holds the tenant ID $TenantID
Is there a way to link to a different section in Dynatrace such as https://{environmentid}.apps.dynatrace.com/ui/apps/dynatrace.infraops/explorer?perspective=Default using a markup tile?
I can do it using code, then visualize it as a table and column = markdown, but it doesn’t look good.
The simplest solution: you actually don’t need $TenantID at all
Dynatrace markup tiles support relative URLs, and the current environment ID is automatically inserted by the browser.
So you can link to InfraOps like this:
