Dashboard ownership changes
In latest Dynatrace, what happens to the dashboard when a user who has created it is no more associated with the tenant? His ID in Dynatrace is removed as well.
Would the dashboard disappear?
Hello @SrikanthSamraj ,
If the dashboard is shared with others, they will continue to have access to it and it will function as expected. However, if the dashboard is not shared with anyone, it will be removed from the tenant.
BR,
Thanks @Akhil-Jayendran . In dire need, can it be restored by Dynatrace product team if dashboard was shared with someone but without change to ownership?
Hi everyone,
You could also use this new feature https://{environmentid}.apps.dynatrace.com/ui/apps/dynatrace.settings/settings/document-management
