Dashboard reuse of search amongst panels
Often in a dashboard many of the panels are showing different views of the same data.  Is there some way to define the for DQL search for the dashboard and then maybe add different summarizing or sorting criteria for other panels.
This would mean that if I need to change the main search I only have to do so in one place.
Great topic in terms of DQL and dashboarding. Dashboarding can be used in a specific/granular segment if so desired. But the trade off is the lack of universal filtering. For example, If you are filtering on Hosts where the tag = EasyTravel for an app, it will render your tile invalid if you select a Management Zone that does not include entities that have the defined tile filters, it will not render.
Its a tricky dance based off the overall goal of the dashboard, do you make it super specific, or generic to allow the overall use across teams and such.
Can you give details on how to reuse “specific/granular segment[s]” in a dashboard? I’ve so far been reduced to crude copy/paste for each panel that uses the same results but different visualizations. Ditto for workflows.
I’m assuming this topic is similar to https://community.dynatrace.com/t5/Dashboarding/Dashboard-reuse-of-search-amongst-panels/m-p/237051 which hasn’t gotten much love.
