Events are visible in entity level as host level, process level, etc.
Can we create a dashboard with events summary of more than one entity?
Something similar as you can do using DQL and “fetch events” but in Managed.
Best regards
Best regards
I was talking to support about this. This is possible if event is linked to a metric.
For example, if event is about host restart, you can check host availability metric.
Best regards
