We’ve noticed that a lot of extensions are beginning to upload default dashboards in the new UI.
However we don’t have the ability to use the management zones to filter the data on those nor on the self-created ones for that matter.
They are promoting segments for this however there are a lot of big differences between segments and management zones. Although technically you can do the same with both, because of the differences in syntax for the filters you have to adapt every management zone (which can have exclusions in filters) to segments (which only have inclusions in filters).
I already have a statement to create the variable for the management zones but that variable can’t be used to effectively filter the data to be shown. This is still one of the main reasons we can’t move to the new dashboards as our entire security model is based on management zones as directed by dynatrace at the start of the project.
So in short, it would be nice to have the management zone back as main filter on top of the dashboards and like in the classic you should be able to have any widget adhere to it or have a fixed management zone.
