You can also use the environment/Configuration API to export the Json data for the dashboard you are looking to duplicate in another environment. Then just run that Json in the post API for the desired environment.
creating Dynatrace configuration backups and reusing this configuration on different environments is very important. We’ve missed such a feature for a long time and developed a tool called Composer to close this gap.
