When doing a query in data explorer, I have a list of 15 applications. I want to know if I don’t specify a split, does the query automatically include ALL applications? It’s not clear to me what the default query would be.
That seems about correct!
As you have it, If you do not specify the ‘split by’ it will reflect the bounce rate of all applications (builtin:apps.web.bouncedSessionRatio:splitBy():sort(value(auto,descending)):limit(100))
will show like this.. which then if you want to, you could hover your mouse over and will see the option to open ALL your applications:
As for the answer, I believe what you are looking for, in this case, you could add in your query to split by: “dt.entity.application” >> the full query would be: builtin:apps.web.bouncedSessionRatio:splitBy(“dt.entity.application”):sort(value(auto,descending)):limit(100)
Now, the easier way, would be just to simply use the “BUILD” option we provide you and set the split by from the options given for that specific metric (apps.web.bouncedSessionRatio).. on this case, you will see: Web applications, Users and Users Type
