Data is currently in a string from a csv for example
2026-05-13 22:51:49.585,email@email.com,service,com.corp.ag,DENIED,“designer, app-user”
Need to parse it so the data is in format:
| timestamp | user_email | service | domain | access | field1 | roles |
| 2026-05-13 22:51:49.585 | email@email.com | service | com.corp.ag | DENIED | | designer, app-user |
The issue being the final field is encapsulated within double quotations and has a comma, and there is a field1 value that is null. Using DPL it doesn’t like the blank field, and using splitString(data, “,”) splits most of the data correctly but incorrectly the final field which is meant to stay together.
