Database monitoring for services and transactions
There are some situations where I have observed when the application calls to the database to pull the records but when I tried to see records in Dynatrace under database it was not showing any entries (SQL statements)whereas in the dashboard it was clearly showing a number of times DB was called.
To fix this, “entity selector” option can be used like below. Make sure services are having tags.
you will get all databases that have been called through services.
Sujit
Great Tip, Thanks @Sujit
