Do we have any option how to customize alerting rules for VMWARE datastores (setting different thresholds for datastore)?
Custom disk monitoring rules are available only for hosts monitored with Oneagent. We can either disable datastore monitoring completely or disable automatic thresholds and put a single percentage rule across all vmware hosts - which however does not fit at all.
@Julius L. this is a great use case and unfortunately there currently is no solution for you to set datastore space by datastore, its a one for all setting across the environment. Granted this question was asked in 2018, its 2020 now and there is still no change in the alerting settings for the Datastore.
I would recommend tossing in a RFE for this. You can do so by clicking the following link: https://community.dynatrace.com/t5/forums/postpage/board-id/DynatraceProductIdeas
