In the Davis stage of a log pipeline, if I set the property dt.davis.is_frequent_issue_detection_allowed = true, will it affect whether events with recurring patterns are raised?
Thank you very much to any expert that will be willing to answer with their deep knowledge and first hand understanding. (Don’t AI-nswer me please)
Yes, the flag basically allows Davis to apply frequent-issue-detection on the event, imagine sending same raw event but through the API.
You can find the official event property definition under the event properties API
"key": "dt.event.allow_frequent_issue_detection",
"displayName": "Allow frequent issue detection",
"description": "The flag controls whether the Davis® engine should consider suppressing frequent events (true) or bypassing frequent issues check (false).\n\n\n\nThis property can be written by most event sources, such as Events API, metric events, log events, or Extension 1.0 events. \n\nFor extension 1.0 events, the value must be specified as a string.",
"writable": true,
"filterable": true
Do you think there could be pros and cons of applying this property to log events rather than a events based on timeseries in Anomaly Detection?
The pros/cons are basically up to you to decide, if it makes sense to add to custom events.
I can strongly recommend having a read through the doc
I think this sentence brings it to the point:
Problems that are less severe and have a shorter duration than previous alerts are considered to be frequent issues and so alerts are suppressed for these. For details on event severities, see event types.
@Yann_Buccellato I was recently exploring a similar option and in my case “dt.davis.is_frequent_issue_detection_allowed = true” was not really a useful option for logs , but I did find generating events based on log content in the Davis stage of the log pipeline better than using anomaly detection alerts.
However, there are also other event properties that might impact the behavior of event generation in the pipeline ie., “dt.davis.timeout” and “dt.event.correlation_tag”.
“dt.event.correlation_tag” plays a major role on how the events are correlated and problems are generated . By default event.name, dt.source_entity, and event.provider are used , but these were not good enough for generating events based on log messages so had to update the correlation fields for my case .
The intention was to capture specific errors every time they occur as they were important to us , so using frequent issue detection was not a best option for us.
Again, your scenario might be different. I’m just explaining what worked for me
