Hi All,
We have implemented generic DB queries in our environment customer has can up with a requirement for a single queries if we can plot below metric and enable alerting for it. Can any one please help me on it.
- I/O Requests (per second)
- I/O latency
- I/O Megabytes per Second
- SQL Service Response Time
- Network Traffic Volume Per Sec
- Temp Space Used
Regard’s,
Vikas A Goud
Hi @Vikas_g199
You define the thresholds for a specific metric (if you do not want to rely on automatic ones) in the Metric Event.
In the next step you need to define the Alerting Profile and the integration method (e.g. e-mail)
Radek
Hi Radek,
Thanks your reply can you please confirm below metrics to be plotted on dashboard and create alerting for Generic DB query.
- I/O latency
- Temp Space Used.
Vikas A Goud
