I would like to build a dashboard to measure our license usage for:
Host Unit,
DDU (including cloud log forwarding usage, how do I differentiate?),
CAU (Cloud Automation Unit),
DEM,
Application Security units.
Is this possible? If so, how?
Host Unit,
DEM,
In DataExplorer/Metrics look for metrics starting with “builtin:billing”. They can be used to construct graphs with DDU/DEM usage, with DEMs being shown as sessions & synthetic actions. They can then be shown in dashboards.
For the remaining, there is not an easy way to pin them to a dashboard, at least that I know of.
Thank you @AntonioSousa . Do you know what the metric names are for Cloud Automation Units, Host Units and Application Security Units?
Regarding Metrics, I believe none of the 3 you cited are available.
From the API, for what I know, the ASUs & CAUs are still not available. For HUs, check the following post, and look for “consumedHostUnits”:
https://community.dynatrace.com/t5/Dashboarding/Host-Unit-consumption/m-p/110502
An important aspect is that if you are using Managed, than there are more possibilities with this API:
https://www.dynatrace.com/support/help/setup-and-configuration/dynatrace-managed/cluster-api/cluster-api-v2/license/get-retrieve-license-consumption
