Hi Team,
We are encountering an unusual issue after installing OneAgent on three of our domain controller servers. Upon verifying the processes discovered out-of-the-box (OOB), I noticed that a critical process, Microsoft.ActiveDirectory.WebServices.exe, has been identified on all of them.but the deep monitoring is not enabled due to issue in internal configurations
I attempted to manually enable deep monitoring for this process, but it did not start, Since this process is critical for monitoring, please advise on the next steps.
I would say, enable deep monitoring, be sure process injection is enabled and restart process.
Best regards
I did enable deep monitoring manually, but the issue did not resolve. i have requested a restart from the client for the particular process lets see
Hi Abidyaseen,
If restarting the service doesn´t fix the problem, try to reinstall OA.
Hope it helps.
Elena.
The issue resolved after restart thanks
On Windows hosts, this could happen if the oneagentmon device is disabled.
If disabled, enable it and restart the process; if that fails, restart the host.
