Define a technology in a custom extension
Hello all,
I am creating a custom extension with prometheus data source, in which I have a custom device, I wanted to try to understand if it is possible to define the technology for this custom device so that it appears in the UI in the Technology & Processes menu.
I can find the custom device if I do a general search, but I can’t find it in the technology menu, nor in the custom devices.
Thank you,
Henrique M.
No, this is not possible.
Thank you for your answer James.
