Deploy Certificate Monitor Extension for SSL Certificate Tracking
Does anyone use the SSL Cert Monitor extension to monitor SaaS SAML certificates ?
Are there any specific configurations areas that need to be considered for SAML monitoring ?
Appreciate any feedback.
Kind regards
Rob
Hello @RobertDring
Simply you will apply the available procedures provided by Dynatrace through Hub
  • Enable active port discovery.
BR,
Peter
