Please suggest how to use above ..If possible please share steps
Want to monitor linux container app
What service on azure are you using to run your container?
You might want to check out OneAgent on Azure App Services.
Thanks for Reply : But Oneagent on Azure App Servies Extension in not availbale for Linux Apps.
Hello everyone,
Here you can check out the documentation article on how to integrate OneAgent on App Service for Linux and containers:
Integrate OneAgent on App Service for Linux and containers
Hope that helps!
