Hello
My Dynatrace is Managed. I have to install OneAgent on a Linux server.
This is the "verify signature " in Dynatrace SaaS:
wget https://ca.dynatrace.com/dt-root.cert.pem ; ( echo ‘Content-Type: multipart/signed; protocol=“application/x-pkcs7-signature”; micalg=“sha-256”; boundary=“--SIGNED-INSTALLER”’; echo ; echo ; echo ‘----SIGNED-INSTALLER’ ; cat Dynatrace-OneAgent-Linux-1.247.225.sh ) | openssl cms -verify -CAfile dt-root.cert.pem > /dev/null
But in Dynatrace Managed, what is the URL? because the server doesn’t have internet allow.
Are you able to download the dt-root.cert.pem file from a host which has internet connection? Then upload the file to the server you wish to monitor which has no internet connection. Run the linux command to verify the signature but point the directory where you’ve placed the pem file.
Malaik
September 1, 2022, 5:47am
3
HI @gfragosoIndra
You can download the package from a machine that have internet access and transfer to your Host (That you want to monitor).
The link to download is:
https://**Put your URL here** /rest/deployment/installer/agent/unix/default/latest?arch=x86&flavor=default
