I have a question about Anomaly detection.
When you press Reset in “Reference period”, including the day you clicked,
I think that seven days of data will be reset.
(For example, if you reset it at 9:00 on February 26th,
Data of 9:00 on February 19th to 9:00 on February 26th is reset. )
This is an effective means when you know that the trend of the system is different from usual, such as temporary work.
Do you have my knowledge, such as the period of reset?
Based on the above, there are things I do not understand.
For example, suppose you pressed the reset button at 9:00 on February 26th.
On 28th February, when the traffic was low unlike usual,
I think the data on February 21th is reset,
Is it detected as Problems compared with data of more than one week ago, such as February 7th and 14th?
Do you know anything?
I am looking forward to your reply.
