Please someone highlight me the exact differences between PG monitoring and Custom PG monitoring rules in Global settings->Process and Containers->Process Deep monitoring.
Hi Gogi,
With Process Group monitoring you can globally set the deep moniotring of recognized processes (on/off). You can check it at the individual Process Group settings as you see.
Custom Process monitoring rules can be use eg override the global rule above. See an example. I did not want to deep monitor the nodemanager process globally (it is not included in the Built-in process group monitoring rules - next menu item).
This is the result:
I hope it helps a bit.
Br, Mizső
Thanks Mizso, its super clear explanation with example snapshots.
Understood, PG monitoring and Custom PG monitoring options are mainly to control “Deep monitoring” at Global level, even we can enable/disable “Deep monitoring” at each process group level but these settings are mainly to control deep monitoring at Global level.
Please let me know whether I have understood correct.
Correct.
