Differences between hostautotag.conf and hostcustomproperties.conf
Hello all.
Please which are the differences between hostautotag.conf and hostcustomproperties.conf ?
Both files can be used for defining tags?
Many Thanks
Damián
I think you should check this link:
Host auto tag is used for tags whereas the other file for the definition of properties.
Thank you very much Radoslaw and Sebastian for your clarifications! Great job.
Damián
