Hi
Could you please clarify the following 3 questions from customer (from senior Architect)?
1.Does Dynatrace at least have some common OOTB integrations with popular PaaS/ SaaS e.g. Azure or ServiceNow at least.
please expand on “some metrics” where there is no agent/connector OOTB - what is the extent of the APM functionality we can get from say an unsupported SaaS- what alerts/ events can we see ?
2. **Main functions of ActiveGate--**What specifically is the network overhead? Add some metric to define the network usage.
3.Is there a different deployment model for Dynatrace that does require extensive use of ActiveGates/ Proxies in DMZ? Is this required purely for connectivity to the Server in AWS or does it perform throttling/ compression of data?
Thanks&Regards
Sangeetha
Thank you so much Sebastian for the response
one more question pleasae
How to monitor remote nodes without oneagent installed? Or
The detail of the metrics captured on Saas/PaaS without agent
Give me more informations about what kind of nodes? You mean AWS / Azure? Or some devices that are in network but you cannot install OneAgent on them?
they require metrics on SaaS/PaaS without agent installed node:Azure
Actually under monitoring Pass/Saas section customer has below question
Monitoring PaaS/SaaS: "expand on “some metrics” where there is no agent/connector OOTB - what is the
alerts/ events can we see ? "
For Azure you just need to configure integration in Dynatrace. That’s all. There is nothing more you can configure. Azure is sharing some metrics about entities using API, dynatrace is fetching those data and pushing it to dynatrace.
