Is there a way to dimension Grail storage, specifically logs? I have a few different API’s that are sending data but don’t see a way to dimension the grail storage. I hate to send them to different buckets simply to allocate the volume of data but not sure of another option.
Hello @ronmacdonald!
I don’t get what you mean by dimension. Do you mean the ability to select the assigned bucket for the logs?
Sorry, could have worded better. I have multiple feeds into Dynatrace. I would like to measure the volume of each of the feeds. Looking at the metrics for buckets, I don’t see a way to “dimension” the amount of space in a bucket by any piece of meta data. For example, split by `dt.auth.origin` or `security.context`…
