Disable chatbot protection in a synthetic
We would like to test the chatbot in one of our webs to be sure the chatbot functionality is working fine. We want to:
  1. Enter in the web
  2. Open the chatbot
  3. Make a question
  4. Receive chatbot answer
  5. Close the chatbout
  6. Close the webpage
But when we run the recorded synthetic previously, the chatbot detects Dynatrace synthetic browser and the question can´t be made.
Is any way to skip this protection? Maybe adding a header in the settings of the browser clickpath?
Thanks in advance.
Elena.
I was thinking that. Maybe playing with User-Agent header, but not sure if that will work.
Best regards
Hi Antón,
Thanks for your answer. Yes, we’ve though that as solution; configuring the header in the advance setting in the settings of the sinthetic browser monitor. But for the time being there isn’t a header in the chat bot to identify that.
So we would like to know if there is any other solution to get skip this protection meanwhile the developers create this header.
Thanks anyway for your answer.
Elena.
Agreed. You can override the User-Agent. By default, Dynatrace uses a User-Agent in the format DynatraceSynthetic/{version}.
Keep in mind that changing the User-Agent may impact the Dynatrace Frontend view, where traffic is categorized as Real Users, Synthetic, and Bots, since this classification relies partly on the User-Agent string.
This approach often helps bypass basic bot detection
Hi Paco,
And do you know if there is any way other way to get that? As I said the header is not created yet and we would like fix till the developers can create the header.
Thanks a lot.
Elena
The user agent is automatically sent by the synthetic browser (chromium) you need to configure it here.
Hi Paco,
Yes, we’ve configured on this way and it works. But we had to run the synthetic in a private location. From public location doesn´t work.
Thanks a lot again
Elena.
