Hello everyone, I have issue need fix
I disable monitoring by using Host ID but it loss many time. So can anybody help me to disable monitoring by using Host Group ?
You can use the BizOps configurator
BizOpsConfigurator (dynatrace.github.io)
Enter your API token, tenant URL and the host group to deactivate and then set monitoring enabled to false. This way you could also change the monitoring mode.
@marina_pollehn please let me know what scopes we should use for API Token here, Iam getting token related errors.
Hi, is this still working?
