Disable RUM Monitoring during Maintenance window
I want to exclude any monitoring that consumes DEM units (Synthetic Monitoring and RUM) in the maintenance window. I found that Synthetic Monitoring can be disabled. Is there a way to also disable RUM monitoring in the maintenance window?
That feature is not available for RUM.
You can raise a product idea.
Best regards
Hi @Aboud ,
You can create a workflow to disable/enable RUM. You can use a cron schedule trigger to disable/enable RUM according to the maintenance window. Here you have an example that disable/enable host monitoring that can help you to build your workflow.
Hope it helps.
Elena.
Hello @AntonPineiro
Another question: should I close or disable the RUM application on a per-application basis through Application internal settings (for enablement and cost control)? It would be quite a lot of work to go into each application to disable RUM individually.
Alternatively, can I disable it from the global settings (Settings → Web and Mobile Monitoring → Enablement and Cost Control)?
Do the internal application settings override the global environment settings?
@erh_inetum is already pointing to you. If you cannot use Grail / Workflows, I would say using some custom script + API.
Best regards
Yes, you should enable/disable per application because internal application settings override environment settings.
As @AntonPineiro suggested, you can develop an script using API calls to do this.
But using a workflow, it’s not necessary developing an script and you can programm the execution from workflow.
Hope it helps.
Elena.
