Disabling an alert on traffic drops
we are receiving this alert frequently irrespective of traffic. Can someone help us with how can we disable this alert in managed?
This is configured under anomaly settings. You can change the threshold or just disable the problems based on that under “applications.” You can also edit the individual application specific anomaly detection settings to change it for individual applications:
James
We are also facing the same issue, but I am wondering why we would get unexpectedly low traffic alert although there is traffic ?
Regards
Rohit Sharma
Dynatrace is learning patterns of such things like traffic. So in such case when there is violation of this metric it can be raised as a problem. It is possible thet there was traffic drop from short amount of time but it fulfilled incident and problem has been fired.
We see this alert as always just noise. The best setting for this is OFF.
We get this alert regularly when there’s a quiet period such as a holiday.  I have switched the “detect traffic drops” off too.
