Disk space alerts - severity level
Currently Disk space alerts coming as Resource event and it is coming as P2.  so we need this disk space alerts to come as slowdown event so that it will come as P3.
How do we do this in our env?.
Hi @sundarv1
Disable these deafault disk anomaly detection settings:
Create yout own metric evenets for disk metrics with slowdown category:
I hope it hleps.
Best regards,
Mizső
Hi Mirzo - when i create own metric event, it is asking many options to fill. we want to get slowdown event if disk space is less than 10% for all hosts. how to do this
Hi @sundarv1
You can use metric expressions:
for hot level:
for disk level:
Then:
I hope it helps.
Best regards,
Mizső
Hi Mizso
I have attached the word document from our env. Is this fine?.
Metric Key Event.docx (73.7 KB)
Hi @sundarv1 ,
The doc does not include the whole settings, but this will be disk level alert as I see.
Best regards,
Mizső
