Disk vs Disk Edge - alerts coming from both settings
hello,
I’m new to Dynatrace and I tried to configure disk monitoring, but I’m facing an issue:
Disk on environment level, 15%
I set up an environment-wide disk usage threshold of 15%.
Disk edge on host level, 13%
On a specific host, I separately configured a disk edge threshold of 13%.
Why I receive alert from both? Is it okay that alerts are coming from both settings?
Disk Edge is an improvement to before one. If OneAgents are sufficient updated, you can use only Disk Edge, since it has more flexibility.
Best regards
