Display "0" for no data in the custom chart
Is there a way to display “0” on data explorer chart when there is no data for the said period instead of the “No data” info
Anish
This was wrong correct answer in edit:
You can select the option to connect the gaps in the graph, but you can’t force it to show zero for no data.
EDIT:
Thanks for the link @AgataWlodarczyk the default Operator is now working for this use case!
Only 2 values in interval without default:
With default 0 it replaces no data with 0 as well:
You can find detailed explanation in the thread => Replace No Data by 0 in Dashboard
